Shows forwarding hardware table utilization statistics.
hardware-utilization | Specifies showing hardware table utilization statistics. |
slot | Specifies selecting slots. |
slot_num | Specifies which slots to show statistics for. |
all | Specifies showing statistics for all slots. |
Shows forwarding hardware table utilization statistics with L2, L3 and ACLs configured.
The following example shows table utilization statistics:
# show forwarding hardware-utilization Hardware Table Utilization Statistics Slot: 1 Type: X870-32c Resource Type Current Maximum % Util. -------------------- ------- ------- ------- MAC Entries 0 73727 0 Host Entries 0 73728 0 IPv4 Entries 0 73728 0 IPv6 Entries 0 36864 0 Long IPv6 Entries 0 2048 0 Total Routes 0 16384 0 IPv4 Neighbors 0 N/A N/A IPv6 Neighbors 0 N/A N/A IPv4 Routes 0 N/A N/A IPv6 Routes 0 N/A N/A ECMP Next Hops 0 1023 0 ACL Ingress Entries 40 6144 0 ACL Ingress Counters 0 38912 0 ACL Ingress Meters 0 2048 0 ACL Ingress Slices 0 12 0 ACL Egress Entries 0 1024 0 ACL Egress Counters 0 1024 0 ACL Egress Meters 0 1024 0 ACL Egress Slices 0 4 0 ACL VLAN Entries * 1 2048 0 ACL VLAN Slices * 1 4 25 Legend: N/A - Maximum not defined in published sFlow structure. * - Resource type not defined in published sFlow structure. Also see IP usage in 'show iproute reserved-entries statistics'.
This command was first available in ExtremeXOS 22.6.
Legend explaining N/A entries was added in ExtremeXOS 30.1.
ACL VLAN entries and slices was added in ExtremeXOS 30.7.
